Battery compatible retroid flip?
My original Retroid Flip battery ballooned overnight and I would need to buy a compatible (size and power) one to replace.
Это хороший вопрос?
Это хороший вопрос?
@squeepty usually there are numbers printed on the battery with which you can identify the battery. Post some pictures of your battery with your Question so we can assist you with that. Добавление изображений к существующему вопросу Yours could be a 655093G 3.8v 5000mAh 3.8V battery.
If you can't find it by the numbers, measure your battery and then search for one (AliExpress etc.) for one that has the same electrical characteristics and dimensions to fit your Retroid. There can always be issues if these are custom batteries. If so you can always go smaller in physical size as well as mAh which will just lower the time your Retroid can be on battery usage.
Был ли этот ответ полезен?
За последние 24 часов: 1
За последние 7 дней: 10
За последние 30 дней: 32
За все время: 484
