interior lights flashing all the time
About 6 months ago my 2011 f250 6.7 interior lights and cab lights started flashing at the same time the pats system started acting up saying key not programed now ignition sometimes won't shut off the engine I have to pull ignition relay
Это хороший вопрос?
Счет 0
Добавить комментарий
1 ответ
Наиболее полезный ответ
@michaelran54368 the flashing interior lights and cab lights are usually an indicator that the BCM needs to be reprogrammed. The BCM also controls your key program. Looks like your BCM does need to be either reprogrammed or replaced. The right OBD scanner for your vehicle might give you more detail.
Был ли этот ответ полезен?
Счет 1
1 Комментарий:
I have a snap on verdict scanner only codes im getting is for a communication issue due to low voltage and that's from when the ignition doesn't want to shut the truck off usually when that happens I have to pull the ignition fuse and disconnect battery and only then will everything work again
из
Добавьте свой ответ
michael rankin буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 3
За последние 7 дней: 6
За последние 30 дней: 35
За всё время: 448
