Ninja Foodi SP101 — это цифровая аэрогриль-печь, которая выполняет функции аэрогриля, тостера и конвекционной печи.
How to Remove Side Panel?
I have been struggling to get the side panel on this removed. I am aware the guide here says to unscrew the 3 screws and then push the panel towards the control panel until the clips are visibly detached
However I have not been able to produce this result with varying levels of force. There is something towards the control panel that is firmly holding that side of the panel in place no matter what I try.
Это хороший вопрос?
Счет 1
Добавить комментарий
1 ответ
It works with light force, so there's probably still a hidden screw that needs removal. For me, it was the TR10 (security Torx) on the inside left front wall middle near the door, covered in grease. So in total you remove the black plastic bar screws, the back panel screws on the side you want to remove, and the screws underneath the bottom flip tray on the side you want to remove.
Был ли этот ответ полезен?
Счет 0
Добавьте свой ответ
Luke Davis буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 2
За последние 7 дней: 21
За последние 30 дней: 61
За все время: 341
