Rear wheel and axle problem
I got quoted $3k for "rear sub frame new arms with toe adjustment cam bolts" for a 2018 Honda Odyssey. Is this a serious problem besides uneven wear on the wheels?
Это хороший вопрос?
Это хороший вопрос?
Unless the bushings are worn, which is unlikely, theyre probably quoting the arms because the cam bolts are seized into the bushing so the alignment cannot be adjusted, meaning the tires will wear unevenly, but shouldn't pose a safety concern. However, if theyre quoting the subframe with it, that usually indicates that its rotted out and can cause potential safety issues if it let's go while driving
Был ли этот ответ полезен?
За последние 24 часов: 0
За последние 7 дней: 1
За последние 30 дней: 11
За всё время: 166
