20-, 23- и 30-дюймовые ЖК-мониторы в алюминиевом корпусе, представленные Apple в июне 2004 года. Модели A1081, A1082 и A1083 соответственно.
Large Yellow Bar Running Vertically
I purchased this display used, and I haven't had any problems with it until recently. A thick, faint yellow line has been showing up vertically through my screen. Restarting and unplugging hasn't worked. After it's been on a while, sometimes it will disappear, but lately—it's been staying all work day. Does anyone know what's causing this? Photos below!
Photo #1: Screen with yellow line issue.
Photo #2: Original cord has electrical tape on wire. (I bought it like this.)
THANKS!
Это хороший вопрос?
Счет 1
5 Комментариев
Howdy there, has the display been moved in a way that could have damaged it? Also is this the display the 27" model that only have the thunberbolt and magsafe connector shown here?
из
@jmehnert - These are the older DVI connection and you need a DVI to mDP port or Thunderbolt port adapter.
из
@jmehnert Hey! Thanks for your reply! Yes, it's the 27" model. Your link took me to the main "repair" area—I didn't see a specific magsafe connector image to compare the two!
из
@danj I'm not sure I follow. I have my Thunderbolt connected to my computer using this adapter: https://www.apple.com/shop/product/MYH93... It's been fine until now the yellow bar is showing up.
из
@reneeswigert - This is the older DVI model, yours is a TB2 with a TB3 adapter for your systems USB-C connection. As it turns out the TB3 interface offers multiple services old USB, mDP and USB-C based as well TB!
из
Добавить комментарий
1 ответ
Наиболее полезный ответ
This is a kind of TAB error when the LCD glass and the flex cable are bonded together a connection can get broken which in this case causes the yellow bar. Sometimes massaging the interface can get it reconnected. But that will require a bit of disassembly to gain access to the back of the LCD panel.
While the cord is cracked which is likely why it's taped, you might be able to locate a replacement cable.
Был ли этот ответ полезен?
Счет 1
2 Комментариев:
Thanks for the insight! I'm pretty handy (as long as it doesn't involve soldering!), and I don't mind opening it up per the ifixit instructions I saw. I picked this monitor up for $150, so I don't have that much into it. Can't hurt to try!
из
Hi Renee, have you fixed the yellow lines? I'm having the same issue with my Thunderbolt Display
из
Добавьте свой ответ
Renee буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 1
За последние 7 дней: 3
За последние 30 дней: 22
За все время: 378
