Reset ipad mini5 wifi
Screen rolls over to black screen, that is unusable. Need to reset ipad.
Это хороший вопрос?
Это хороший вопрос?
You can boot your IOS device into recovery mode to access a boot menu and restore it from iTunes or the Devices App.
Here is a link to the apple doc for accomplishing this:
https://support.apple.com/en-us/108925
You will want to connect the device to the recovery device and press and hold both he power and home buttons until the iPad turns off and then release the power button but continue to hold down the home button until you see the recovery boot menu. You should have a couple of options depending on your device and what recovery options/backups you have.
Был ли этот ответ полезен?
It's recommended to force restart your iPad first, as this might get it working normally again.
Just a heads-up: resetting your iPad will erase all your data and settings. Also, if Find My was turned on before the reset, you’ll need to enter the associated Apple ID and password afterward to get past the Activation Lock.
If you’ve got a computer, you can use iTunes, Finder, the Apple Devices app, or tools like Passixer iOS to restore your iPad to factory settings. Alternatively, if you have another phone, you can log into iCloud Find My on it and erase your iPad remotely — just make sure Find My iPad was turned on beforehand for that to work.
За последние 24 часов: 1
За последние 7 дней: 8
За последние 30 дней: 48
За всё время: 455
