The volume buttons problem
The volume up button is glitched (it mostly turns up without even touching it and i have to click the power button to turn it off)
I have to hold the low volume button hardly to lower the volume . Any advice?
Edit:now my power button doesn't work properly
Это хороший вопрос?
Счет 0
1 Комментарий:
What device is having the problem (make and model)?
I have TV remote controls and after a while the buttons don't work, but might if you push really hard, or on one side or the other.
I used a keypad fix on them, and that helps, for a while, but often the "paint" used for the repair flakes off and the button will activate continually, but maybe I'm applying it incorrectly. Look on-line for KeyPad-Fix (Idolon Technologies) or similar.
If it's a mobile phone, I'm sorry, I can't help you with that.
из Поделиться
Добавить комментарий
