Автомобиль Malibu был полностью обновлен для седьмого поколения 2008 года. Это поколение Malibu выпускалось во многих комплектациях: Base (только 2008 год) (1SB), LS 1LS (или 1FL для автопарков 2011 и 2012 годов), LT 1LT (или 2FL для автопарков 2011 и 2012 годов), Hybrid (только 2008 и 2009 годы) и LTZ 1LZ. Только топовая комплектация LTZ оснащалась прозрачными рассеивателями стоп-сигналов с красными светодиодами, остальные комплектации сохранили красные рассеиватели с обычными лампами стоп-сигналов.
What wrong with my car
the engine shakes and doesnt go past 30 miles per hour
Это хороший вопрос?
Счет 0
Добавить комментарий
1 ответ
Наиболее полезный ответ
Hi Shauna,
Since 1996 all US cars are required by law to have an On-Board Diagnostics (OBD-II) port and a standard set of protocols for communication. The OBD-II port allows you to hook up a scanner and read out the Diagnostic Trouble Codes (DTCs) generated by the engine computer. Any problem bad enough to cause your car to run like it is should almost certainly cause one or more trouble codes to be set.
So the first step for you is to find out if there are any trouble codes present. If there are, they will give you and us an idea of where to look for the problem. Here in the US, most auto parts stores will hook up their scan tool to your car for free and give you a list of any codes they find. Alternatively, you can buy an inexpensive OBD-II scanner at the auto parts store or online; some of them are pretty cheap. There are also Bluetooth dongles that plug into the port and link to your phone; you can download free apps to read out the DTCs; I personally use one called Torque. Those dongles can be had for around $5 or even cheaper online.
Once you have that list (or find there aren't any codes), come back and edit your post to add that information. The codes will consist of a letter followed by four numbers, such as P0103 for example.
Once we know what kind of codes you have, we'll be better equipped to try and point you in the direction of a fix.
Был ли этот ответ полезен?
Счет 1
Добавьте свой ответ
Shauna Rae буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 2
За последние 30 дней: 12
За всё время: 205
