Информация по ремонту и руководства для обновленной версии Retina MacBook 2015 года, выпущенной в начале 2016 года. Модель A1534 / EMC 2991
Boot sequence issues and full blast fan while running
Good day, I have a 2016 MBP, battery is dead and i need to be plugged in to use it.
The issue is, i need to press the power button then plug it in to make the MBP start. Then the fan is in full blast while im using it.
Just upgraded to Sonoma via Opencore, works great.
My Main question is; what is the issue when starting the laptop. is there a hardware problem?
Thanks
Это хороший вопрос?
Счет 0
Добавить комментарий
1 ответ
Given the systems age I'm suspecting the battery has failed, install this Gem of an App CoconutBattery it will allow you to see mot]re clearly the batteries health. Post a snapshot of the Apps main window here so we can see as well.
Был ли этот ответ полезен?
Счет 0
2 Комментариев:
Hi @Dan, Yes i think the bat is dead. WIll changing the battery help in booting process issue? and Fan on full blast?
из
@jujoe - If the systems sensors are telling SMC there is a problem, the SMC logic will lower the CPU's clocking as well as pump up the fans RPM as it's going into CPU Safe Mode. I suspect that is what you are seeing which is likely the Battery, but without proof of seeing the CoconutBattery screen shot I can't tell you it's the battery alone.
из
Добавьте свой ответ
jujoe1 буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 1
За последние 7 дней: 9
За последние 30 дней: 18
За все время: 209
