Информация по ремонту и разборке смартфона Google Pixel 7, выпущенного в октябре 2022 года. Идентифицируется по номерам моделей GVU6C и GQML3.
Screen detached from plastic safety frame
The battery was swollen and pushed the screen out, and when opening the phone I didn’t realise that instead of separating the screen with its frame from the chassis I was actually separating the screen from the safety frame.
The photo above should make it clearer.
Now I imagine the obvious answer would be to get a replacement screen but tbh having already spent 80€ for the battery kit I don’t think it’s worth it (also the screen is fine)
Any chance I can reassemble the screen and frame? What glue could work?
Это хороший вопрос?
Счет 0
Добавить комментарий
1 ответ
I ended up carefully cleaning frame and screen with isopropyl alcohol, then used a thin layer of T8000, let it dry a few hours before proceeding with reassembling the screen to the device, and finally leaving the phone under a stack of books for 24 hours.
I guess I'll have to report back in some time to see if it holds, but for now the result was quite good. It's most likely not waterproof anymore but I mean, at least it won't blow up anymore.
Был ли этот ответ полезен?
Счет 0
Добавьте свой ответ
Giorgio буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 6
За последние 30 дней: 20
За всё время: 216
