Руководства по устранению неполадок, разборке и ремонту Samsung Galaxy J7 2016 года выпуска, номер модели J710.
My back button are not working
My bottom 3 button are not working
Это хороший вопрос?
Счет 0
Добавить комментарий
1 ответ
It's possible the connector for the buttons and lower speaker has come loose; does your sound also not work on the phone? If so, that would indicate an issue with the flex assembly that holds the buttons and speaker connector so it would be worth your time to try and reseat that connector. Here's a guide showing how to replace that assembly.
Manuales / Samsung Galaxy J7 (2016) / Flex front buttons and audio connector - Nadie Me Llama Gallina
I would suggest following the first three steps then skip forward to Step 5 where the second picture shows where the button/audio connector is. Unplug it and clean both sides with 90% or higher concentration isopropyl (rubbing) alcohol then reconnect it and see if it's working any better. If not, you may have to replace the flex cable as show in the complete guide.
Был ли этот ответ полезен?
Счет 0
Добавьте свой ответ
Welsondsouza буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 1
За последние 7 дней: 2
За последние 30 дней: 12
За всё время: 148
