Dustbin empty cycle stuck
I’m having a persistent issue with my Roborock S8 MaxV Ultra and hoping someone here has run into the same thing or has a fix.
Problem Summary:
Whenever the robot returns to the dock to auto-empty the dustbin, it gets stuck in the emptying cycle. Physically, I can hear the dock vacuum start and stop, but in the Roborock app, the emptying process never finishes. This causes two major problems:
- The robot won’t start charging.
- If it returns mid-cleaning, it won’t resume cleaning after docking.
What I’ve Tried:(Layman internet suggestions)
- Unplugged the dock and plugged it back in.
- Cleaned all filters and checked for obstructions.
- Power-cycled the robot.
- Verified the dustbin cover is properly installed.
- Checked for blockages in the dock and suction path.
- Ensured the robot isn’t in Do Not Disturb (DND) mode, and verified every setting in the app.
Additional Notes:
- I can manually stop the emptying process via the app, but doing so resets the cleaning cycle, meaning it won’t resume where it left off.
- The dock’s status light doesn’t show any errors, and the vacuum seems to dock correctly.
- I suspect the issue might be with the signal or sensor that tells the robot the emptying process is complete. It seems like the robot never gets that confirmation.
Это хороший вопрос?
