Hi @jose77cccf ,
As you know water and electronics and electricity are not a good mix.
The water causes corrosion and provides circuit paths for the electricity which were not in the phone's operating design and could damage the components.
First do not turn on your phone and then you need to with the phone turned off, remove the battery as soon as possible from the phone to minimize further damage.''
Then you need to dis-assemble the rest of the phone and clean all the affected parts using Isopropyl Alcohol 90%+ (available at most pharmacies) to remove all traces of corrosion and water. Do not use "rubbing alcohol" as in some cases this is only 70-80% IPA or less, can contain scents and other ingredients which may leave residues and is not as effective. If you do check the label to verify the amount of IPA Here are a couple of links that describes the process.
Electronics Water Damage
Repairing iPhone Liquid Damage
As always with electronics, especially surface mounted PCBs be gentle when handling and especially when brushing away the corrosion. You do not want to remove any components from the board.
Hopefully after you have done all this the phone might possibly work correctly again.
Here is a link to the ifixit guide(s) for repairing your phone. (if you have an iPhone 4 that is)
iPhone 4
If this process seems too daunting, take your phone to a reputable, professional phone repair service, experienced in water damage repair and ask for a quote for a repair. If you decide to do this, do it sooner than later.
Был ли этот ответ полезен?
Проголосовали
Отменить
Оценка
2
Отмена
Scroll through this thread to find the appropriate place for this comment. Then, click "Attach comment to this post" to move it.
4 Комментариев
i dropped my iphone 6 in the hottub and it had my life proof case on but it faild to work. my phone works but it keeps turning on and off an shutting off to go back to the home screen or the apple logo. I left it in rice all night idk what to do ?
из kvwardell
My phone keeps crashing every now and then after I dropped it in a puddle not sure what it could be…help
из Billy smith
Ok so I was at school and I kept my iPhone 6 plus in my pocket THE WHOLE TIME. It was working fine until I got home and then when I turned it on it started to glitch and powered off. I know that it is not the battery because it was fully charged when this happened, whenever I turn it on it is always still charged and never dead. Also keep in mind that my phone was in my pocket the whole time and it has the screen protector and the case on. People that I know say that it is water damage but it was in my pocket for the whole day. So how could it have gotten water in it. I am very confused as to why it started acting like this. I've tried everything but it seems to not work. I really don't want to buy another one.
If you have a solution to my problem please tell me. I want to know what has happened. Did I actually ended up getting water in it even though it is impossible that is the case. Am I gonna have to get a new iPhone? Or is it a common problem and can be solved. Hopefully my problem can be solved fast
из nyaboo57
I accidentally left my phone in the rain not too long ago. We put it in rice and took off the screen to let it dry. Now it has a green line down the middle and it turns to a white screen with a black apple logo and then back off to a black screen. I think I may need a new phone and I'm so sad. If anyone knows how to fix this please help!
из Mikaela
