Seized Left Rear Wheel
my L/R wheel is seized,is it the rear hub unit bearing?
Это хороший вопрос?
Это хороший вопрос?
Donna, if it is a FWD model, it is possible that your hub has seized up. Of course, the only way to really determine this is to, jack up the car, remove the wheel, and remove the rear brake. Possibly that your break is causing this too. Check to make sure that the brake shoes from the parking brake are properly releasing, and the the brake caliper is not seized.
Был ли этот ответ полезен?
За последние 24 часов: 0
За последние 7 дней: 4
За последние 30 дней: 13
За все время: 1,570
7 Комментариев
What is your definition of "seized"? what does it do and what does it not do? Did this just start? What type of transmission does it have?
из oldturkey03 Поделиться
wheel will not engage forward or reverse,just happened,auto transmittion
из Donna Поделиться
is it FWD or AWD?
Its All Wheel Drive
из Donna Поделиться
Same thing, check the brakes, see if you can release the brakes and if your wheel will turn. Possible seized bearing or seized rear differential :(
Показать ещё 2 комментариев
