Руководства по ремонту, разборке и устранению неисправностей для контроллера Sony PlayStation 5 DualSense пятого поколения. Идентифицируется по номеру модели CFI-ZCT1W и модели материнской платы BDM-050.
Replacing haptic feedback rumble motors?
I've noticed recently after playing a lot of the f1 game, my haptic feedback is just suddenly extremely weak compared to what it used to be. I've tried pretty much everything I think and nothing works, tried enabling the speaker in my sound settings but my controller doesn't even appear in there. I downloaded dualsense x and tested the right side and left side rumble motors by themselves and the right side is significantly weaker. Wanted to know if replacing the rumble motors would be possible on the V5 since I don't already see any guides here and if so is it just the rumble motors that need to be replaced or anything also involving the triggers?
Это хороший вопрос?
Счет 0
Добавить комментарий
1 ответ
Наиболее полезный ответ
Hi!
The process is nearly the same as V2, V1 ect ect.
So you should be able to use the same guide that is created for the V2 or V1.
How is the haptic feedback? Still good? If yes, then you do not need to replace them, but just the rumble motor it self.
Guide: DualSense Controller v2 Vibration Motor Replacement - iFixit Repair Guide
If the haptic feedback buttons are back or got a lot weaker, then I advise to replace them as well.
Guide: DualSense Controller v2 Adaptive Trigger Replacement - iFixit Repair Guide
So far it does look like you just need to replace the rumble motors.
Please let us know if you have any questions!
DualSense Controller v2 Адаптивные триггеры Изображение
Инструкция
Замена адаптивных триггеров контроллера DualSense v2
Сложность:
Умеренно
30 minutes - 1 hour
DualSense Controller v2 Вибромоторы Изображение
Инструкция
Замена вибромоторов контроллера DualSense v2
Сложность:
Сложно
1 - 2 hours
Был ли этот ответ полезен?
Счет 1
1 Комментарий:
Not muting your mic can override your haptics settings and set them to low or off make sure the button at the bottom is lit orange.
из
Добавьте свой ответ
brending буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 1
За последние 7 дней: 7
За последние 30 дней: 45
За всё время: 806
