Руководства по ремонту, разборке и поиску неисправностей для 24-дюймового Apple iMac с процессором M4, выпущенного в октябре 2024 года.
The mouse no longer functions
The mouse no longer operates. I can see it, but it won’t move. I have restarted it and still nothing. The iMac is only six months old. I tried to connect another mouse and that didn’t work either. Any help would be greatly appreciated.
Это хороший вопрос?
Счет 0
Добавить комментарий
1 ответ
Выбранное решение
While a pain you can use the keyboard arrow keys and the Control/Option keys to navigate via the keyboard. If the keyboard is responding via Bluetooth then the issue is a setting within the mouse Bluetooth settings. You might find it easier to plug in a USB mouse via a USB-C to USB-A adapter. Then open up the Bluetooth settings to re-establish the mouse's connection. Also make sure the mouse is charged.
Был ли этот ответ полезен?
Счет 1
2 Комментариев:
Hey Dan,
Thank you for such a quick response. I tried using the USB-C direct connect option, and as soon as I disconnected it, it came back to life. I REALLY appreciate your help.
Pete
из
@pete78265 - Happy to hear the direct wired connect reset things. If you're set don't forget to accept the answer - Thanks!
из
Добавьте свой ответ
Pete буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 1
За последние 7 дней: 7
За последние 30 дней: 16
За всё время: 264
