Replaced battery ifixit battery
I went through several calibration and reset SMC but still showing 100% charged and shutting down automatically whit 60% charge left. They’re is no low battery warning
Это хороший вопрос?
Это хороший вопрос?
Your iFixit battery likely has faulty calibration or firmware, causing macOS to misread charge levels—contact iFixit for a replacement or warranty check.
Был ли этот ответ полезен?
@wolfganggessl Go to your finder and go to your macbook under locations, navigate to the library / preferences / then delete the 3 or 4 files com.apple.power* / empty the trash then reboot and see if that made any difference. These files will be created new upon reboot.
HI I found the location off the files but I got 5 related to Power
com.apple.powerlogd
com.apple.powerlogd.plist.ADTPLF3
com.apple.powerlogd.plist.W67mu8n
com.apple.PowerManagement.CA179EC3-39EC-5B20-8053-C973A39C784B
Just delete all 5 ?
@wolfganggessl I am using a 2015 15" model, I have 3 - com.apple.powerlogd / com.apple.PowerManagement.EADC2779-E9B8-560C-AC0B-B65836358999 & com.apple.PowerManagement. I would think it would be OK to delete all 5 as they should be auto generated upon reboot.
Interesting!!
I deleted all 5 files rebooted and checked in finder again now I got 3 files recreated
I let you know If it worked after one more calibration sickle
Thank you much for the help
@wolfganggessl Install this app https://www.coconut-flavour.com/coconutb... and post the info together with the system/power report to cross check.
hi still not working sundown this time whit about 70% left
the coconut image is up top
Battery Information:
Model Information:
Serial Number: C01514329YEF90MI5
Manufacturer: ifixit
Device Name: bq20z451
Pack Lot Code: 3230
PCB Lot Code: 3230
Firmware Version: 2d31
Hardware Revision: 322d
Cell Revision: 3036
Charge Information:
Fully Charged: No
Charging: No
Full Charge Capacity (mAh): 6710
State of Charge (%): 78
Health Information:
Cycle Count: 5
Condition: Normal
System Power Settings:
AC Power:
System Sleep Timer (Minutes): 1
Disk Sleep Timer (Minutes): 10
Display Sleep Timer (Minutes): 10
Wake on AC Change: No
Wake on Clamshell Open: Yes
Wake on LAN: Yes
AutoPowerOff Delay: 259200
AutoPowerOff Enabled: 1
Display Sleep Uses Dim: Yes
Hibernate Mode: 3
PrioritizeNetworkReachabilityOverSleep: 0
Battery Power:
Wake on Cl
За последние 24 часов: 0
За последние 7 дней: 2
За последние 30 дней: 16
За всё время: 254
2 Комментариев
Can you post a snapshot of CoconutBattery App main window and post it here so we can see it.
из DanJ
MacBook just shut down this time whit 67% left
Im no expert in this this is why I'm asking here but is it possible the % reported is correct and the Ifixit battery replacement's BMS is faulty
would explain thad I don't get a low battery warning ?
из Wolf
