Automatic Top Feed doesn't work.
The automatic top feed is broken. It will not pull the papers through for printing. There is no paper jam, no dust or anything on any of the rollers or sensors. The feed will just not work with even just one sheet of paper. The gears and rollers in the top section turn by hand. It appears whatever is supposed to be turning them (left front) in the glass top is not working.
Is this repairable and where can you obtain the parts and instructions to fix it?
Это хороший вопрос?
3 Комментариев
I did more digging on this and it appears that it wouldn't be worth trying to fix the automatic document feed so I'm going to not worry about it and just do them one at a time.
из Ivan Yarrow Поделиться
@ivanyarrow before giving up let's see if our printer guru @nick has a solution for you.
из oldturkey03 Поделиться
@oldturkey03 Hopefully the rollers are just bad. I'm not including eBay links due to link rot.
из Nick Поделиться
