Информация по ремонту, разборке и устранению неисправностей iPhone 16, выпущенного 20 сентября 2024 года. Устройство оснащено 6,1-дюймовым OLED-дисплеем, системой из двух камер на 48 Мп и разъемом USB-C. Преемник iPhone 15.
How remove polish smude on screen?
Hello everyone.
I had a scratch on my screen that I tried to get polished in a repair store. Didn't do anything. Ended up putting a screen protector on it. Removed the screen protector today and I see that where the repair guy tried polishing it that there is a smudge that I can't get off, not with 70 nor 100% isoprop alcohol. Is there anything I can do? It isn't really visible unless I put a bright light on it but it kinda bothers me :)
Thank you in advance. See pics.
Это хороший вопрос?
Счет 0
Добавить комментарий
2 Ответов
Наиболее полезный ответ
Sounds like the coating got damaged, if that's the case there is little you can do to repair that, only masking it like putting on a screen protector.
To properly fix will require a new display assembly iPhone 16 Screen and here the guide Замена дисплея iPhone 16
Replace a scratched or cracked front panel glass digitizer screen or a malfunctioning display. Изображение
Товар
iPhone 16 Screen
$139.99
Был ли этот ответ полезен?
Счет 1
1 Комментарий:
Thank you for your input :)
из
I'm guessing the oleophobic coating on the glass got polished off; that's the coating that helps the glass resist fingerprints. I haven't tried this, but there are kits you can buy that are supposed to restore that coating; that's what I'd try if it was my phone. Do a search for oleophobic coating online and you should come up with plenty of choices. Here's one that came up that looks interesting to me.
Amazon.com: ProofTech OLEOPEL Oleophobic Coating Kit for 3 Applications - Anti Fingerprint Wipe On Liquid for All Smartphones Tablets Smart Watches Glasses Camera Lenses and Touch Screens - Bottle : Health & Household
Счет 1
2 Комментариев:
@dadibrokeit Already had anything like this and did reapplying an oleo coating fix it?
из
Again, I haven't had any experience with it, but others have. In fact, it turns out there's an iFixit guide to applying it!
Восстановление или нанесение олеофобного покрытия
из
Добавьте свой ответ
brubel буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 3
За последние 7 дней: 11
За последние 30 дней: 39
За всё время: 632
