Model A1136 / 30, 60, or 80 GB hard drive / black or white plastic front
iPod white screen problem
hello
I have an ipod video the screen was completely white, which sometimes some vertical lines appear when I turn on my ipod.
I tried resetting, but not resolved.
Anyone know the reason and how to solve this problem?
thank you
Это хороший вопрос?
Счет 2
1 Комментарий
time to replace the LCD :)
из
Добавить комментарий
2 Ответов
Выбранное решение
rui,that sounds more like a hardware issue than a firmware issue. Check the connector of the display and make sure it is A: closed properly B: the ribbon cable is still properly connected. If any of those are still okay, I would think it is time to replace the LCD. Here isthe guide for it. The display is available at multiple places, and it depends on your geographical location. After that, reevaluate and see what you get.
Был ли этот ответ полезен?
Счет 1
2 Комментариев:
First of all thank for your reply.
I also get the feeling that will be the hardware issue.
because except the screen, the iPod looks fine. the control menu makes the sound seem normal and the on/off/reset screen seems to look a little different...
I'd like to try a little more option firmware, because he would not give shots in the dark and buy unnecessary equipment or worst purchase equipment and the ipod does not work the same... :(
Before i buy whatever it is, and despite not having the proper equipment will try to make sure everything is well connected.
Thank you once again for your answer. :)
из
rui, thank you for accepting my answer. You could try and install older firmware from here http://www.felixbruns.de/iPod/firmware/ Place your iPod in disk mode, format the drive with your OS and then do a restore with the older firmware. Good Luck.
из
HEY MS. COL.LEY UMM CAN U whach m y kids for a little3 ple4ass
Счет 0
Добавьте свой ответ
rui буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 10
За последние 30 дней: 42
За всё время: 5,756
