Xiaomi Redmi Note 10S — это смартфон среднего ценового сегмента от компании Xiaomi, выпущенный в марте 2021 года. Он оснащен 6,43-дюймовым AMOLED-дисплеем, основной камерой на 64 Мп, сканером отпечатков пальцев на боковой грани, аккумулятором емкостью 5000 мАч и работает на базе процессора Mediatek Helio G95.
Display does not respond correctly to touch
More than two weeks ago, my father had his display replaced because his phone fell and broke the display, but since they replaced the display, he went back to the service centre because the display does not respond correctly to commands. Sometimes it does its own thing. I thought it was a dirty display, but cleaning it does not solve the problem.
Это хороший вопрос?
Счет 0
Добавить комментарий
1 ответ
@piero90 that sounds very much like a bad touchscreen/LCD assembly. Since this happened right form the beginning I would strongly suggest that your dad has the service center replace it once more with a proper replacement. This will not get better on it's own, there are no calibrations or adjustments.
Был ли этот ответ полезен?
Счет 0
5 Комментариев:
My father went to a service centre twice.
из
@piero90 they did replace the screen already?
из
@piero90 sorry to hear this, but something like "Sometimes it does its own thing." is pretty much a sign of a bad display assembly. Let's see if there are other answers that come up with a different idea.
из
My father went to the service centre for the third time to have the display replaced, but the problem persists, so I assume it is a logic board issue.
из
Добавьте свой ответ
Piero Sabino буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 3
За последние 30 дней: 13
За всё время: 242
