Информация о ремонте, разборке и диагностике неисправностей Steam Deck OLED — обновлённой версии популярной портативной игровой консоли от Valve, выпущенной в 2023 году. Дата выхода: 16 ноября 2023 года. Идентифицируется по номеру модели 1030.
Steam deck Battery Health
When I got my Steam deck about a year ago, I would get 8-9 hours in half life 2 and 2.5 hours in cyberpunk 2077, now I get around 6.5-7 hours in half life 2, and 2 hours in cyberpunk, should I replace my battery soon, or wait a bit to replace it, the system still says its at 100% percent health but I don't believe that number entirely.
Это хороший вопрос?
Счет 0
2 Комментариев
could be dried thermal paste causing the CPU temperature to rise and requiring higher fan rpm to cool the console, drawing more power and decreasing battery life. Does your Steam deck feel hot when gaming?
из Поделиться
Not really, if sits around 65-70 degrees when playing a really heavy game like cyberpunk
из Поделиться
Добавить комментарий
1 ответ
Выбранное решение
You probably shouldn't replace your battery right now. All battery age, but if there's only about an hour's difference in battery life compared to when it's new, replacing the battery now would be a waste. A new battery's both expensive and pretty hard to replace if it's your first time fixing stuff. If it works, it works. Wait until the battery life's significantly short or when it starts to bother you a lot, then replace it.
However, if you're really paranoid about battery life or feel like you'd like a few more minutes of cyberpunk, here's the guide.
Steam Deck OLED Battery Replacement
A lot of glue and fragile cables, so make sure you follow the steps carefully. It would be a good idea to read the guide before you actually start to replace it, to get a general idea of the steps.
Был ли этот ответ полезен?
Счет 0
1 Комментарий:
That's what I thought as well, I've repaired adhesive batteries before, but I agree that I should probably wait to replace it.
из Поделиться
Добавьте свой ответ
Caleb буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 14
За последние 7 дней: 67
За последние 30 дней: 263
За все время: 3,352
