My button pad stoped working, why?
it worked allright until i stoped playing with it, some months passed and when i turned the psp on again the buttons stoped working, the d-pad works correctly and everything else too, does anyone have the same issue and know how to solve it??: Thanks
Это хороший вопрос?
Счет 0
Добавить комментарий
1 ответ
Your PSP-3000’s face buttons stopped working because the button contact sheet is dirty, the ribbon cable is loose, or the button board has corrosion. The D-pad still works because it uses a different circuit. Cleaning the contacts or reseating the ribbon cable usually fixes the issue; replacing the button board is the next step and is cheap.
Был ли этот ответ полезен?
Счет 0
1 Комментарий:
To add: here is a guide: Замена материнской платы PSP 300x
Please check step 18 till 20 (they explain here how to replace the input board).
из
Добавьте свой ответ
Tiago буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 1
За последние 7 дней: 17
За последние 30 дней: 39
За всё время: 215
