Olympus OM-D E-M10 Mark II — это 16-мегапиксельная беззеркальная камера, представленная в 2015 году. Благодаря удобной платформе со сменными объективами, камера подходит как для любителей, так и для профессионалов, предлагая широкие возможности по доступной цене.
Warning about internal temp to high
Hi! I have this camera and as soon as I turn it on I get error that the internal temp is to high and it turns off. I have tried updating to latest firmware via SD-card and that worked. I also bought another battery to see if that helps. It seems that the internal temp sensor is broken or something. Is there a method to "reset" internal temp sensor? Has anyone disassembled the camera and know if it is hard to reach the sensor to look at? What would the next step be?
Oh, I also tried putting the camera in the freezer for maybe 30 mins but I instantly get the high temp warning even after that
Это хороший вопрос?
Счет 0
Добавить комментарий
1 ответ
Well I doubt resetting will solve your issue, the alarm it trying to tell you there's a problem something is overheating! Did you get the camera wet or bang/drop it?
Был ли этот ответ полезен?
Счет 0
2 Комментариев:
The camera looks to be in perfect condition and i don't think there had been water. The problem is i have tested to put it in the freezer for 30 min but it warns of heat instantly antway
из
@patrikradacic - it's possible a sensor has failed. But it's not wise to put cameras into freezers! In the warmer chilled section yes but only when placed is a plastic bag with as much air removed! As you don't want condensation to collect inside!
из
Добавьте свой ответ
Patrik Radacic буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 1
За последние 7 дней: 10
За последние 30 дней: 40
За все время: 314
