Nikon D3X — это полнокадровая цифровая зеркальная камера (DSLR) профессионального уровня с разрешением 24,4 мегапикселя, выпущенная корпорацией Nikon в декабре 2008 года.
Clock battery on D3x
I recently bought a second hand D3x, Im very happy with it. I read somewhere (?) that I may need to replace my clock battery. This makes sense to me as every time I take the battery out to recharge, it resets to 2007 and resets the counter. Where is the clock battery on this camera and is it something I can replace myself?
If I recall correctly they gave a battery type in the article, which I sensibly didn't write down.
I trust you can assist me with my current quest. Thank you in advance for being here in the first place.
Bebb
Это хороший вопрос?
Счет 0
Добавить комментарий
2 Ответов
Наиболее полезный ответ
Is this what you are looking for? Replacing D3 Camera Clock battery
Был ли этот ответ полезен?
Счет 1
1 Комментарий:
The clock battery is located in the roof of the main camera battery compartment, concealed by a slide out cover. Its easy to locate and the battery in question you require is a CR1616 - 3 volt battery which are readily available.
I find they last a long time having only replaced them very occasionally on both the D3 and D3X
из
The Clock battery is a 1616 cell battery. It is found by removing the main battery and looking to the top of the battery chamber, here you will see a sliding cover which if you slide out of the chamber will reveal the battery. Nice simple one when you know
Счет 0
Добавьте свой ответ
david bebb буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 1
За последние 7 дней: 2
За последние 30 дней: 20
За всё время: 176
