Информация по ремонту и разборке беспроводной игровой мыши Logitech G305. Идентифицируется по номеру модели M-R0071. Выпущена в мае 2018 года.
Scroll wheel doesnt work properly
İt doesnt detects the rotations direction
For ex. İ am rotating it to front but it detects random imput. İt goes up and down constantly randomised when i move it
Это хороший вопрос?
Счет 2
Добавить комментарий
1 ответ
Наиболее полезный ответ
Hi! I am not super well versed when it comes to mice, but I hope the following may be a bit helping.
This issue can be cause by multiple problems. A few potential causes can be:
  • Dust or debris in the scroll wheel assembly. This would opening and cleaning the scroll wheel assembly. Using compressed air, a brush and/or electrical cleaner to get rid of debris and oxides.
  • The scroll wheel does not make proper contact with the scroll sensor. This could potentially be fix by re-assembling the scroll wheel assembly.
  • That the mouse scroll is worn out, or damaged. This would mean replacing the scroll wheel assembly.
I can not guarantee that either of these are the cause as there are a myriad of things that could cause you issue. Nor can I guarantee that either of these solutions will work.
Anyway, here is a guide on Разборка игровой мыши Logitech G305, and here is a guide on Замена колеса прокрутки Logitech G305. Here is an older Q&A that might prove insightful: Left Mouse Button not working consistently..
Good luck,
Cheers
Logitech G Series Mouse Колесо прокрутки Изображение
Инструкция
Сложность:
Умеренно
10 - 20 minutes
Logitech G305 Изображение
Инструкция
Сложность:
Умеренно
20 - 30 minutes
Был ли этот ответ полезен?
Счет 2
Добавьте свой ответ
Muhammet Emin Çelik буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 9
За последние 7 дней: 30
За последние 30 дней: 163
За все время: 1,463
