Дата выпуска: 21 сентября 2018 г. Модели: A1921, A2101, A2102 и A2104 / Доступен в версиях GSM или CDMA / eSIM или nano-SIM / 64, 256 или 512 ГБ / Серебристый, золотистый или "серый космос" (произносится "iPhone 10 S Max").
Battery Behaving Very Strangely
I recently charged my iPhone XS Max (had its battery swapped out a year ago) and it just remained stuck at the dead battery icon no matter how long it charged. So I swapped the battery with the original battery I kept after having replaced it. The phone then turned on but won’t charge beyond 1% with the battery health not showing and the phone dying soon after. How do I fix this? all help would be appreciated!
Это хороший вопрос?
Счет 0
Добавить комментарий
1 ответ
It sounds like the battery isn’t communicating properly with the system, which is why it won’t charge past 1% and the phone dies quickly. Before trying replacements or repairs, it’s a good idea to run a full battery analysis. That can reveal whether the battery itself is failing, if there are faulty cells, or if the system is limiting charging due to power or sensor issues, giving a clearer picture of what needs to be fixed.
Был ли этот ответ полезен?
Счет 0
1 Комментарий:
Hey there, I tried messing with the pjone for a bit and realized that the battery connection isnt fully seated so it causes the percentage to not read unless extra force is put on the connecter. I have found a *temporary* fix with some tape (between the cable and the metal shield that goes over it) to push the connector down.
из Поделиться
Добавьте свой ответ
TechVid буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 3
За последние 7 дней: 20
За последние 30 дней: 32
За все время: 155
