Руководства по ремонту, разборке и устранению неисправностей для серии смартфонов на Android Infinix Smart 7, включая модель Smart 7 HD (Infinix X6516).
My phone system charge does not work
Это хороший вопрос?
Счет 0
Добавить комментарий
1 ответ
@gervasgideon you are not telling us what you have already tried and what you have already checked. Start with the basics.
First check your charger. Make sure it has proper output. Then check your charging cable. Check to make sure connectors are not bend etc. After that, check the charging port. Clean it of any debris etc., use a few puffs of air to clean it out. If none of this works, get a USB ammeter and see if your phone draws any amperage from the charger. If it does not it is possible that this is a charging port issue or a bad battery.
To check the charging port, use a voltmeter and measure the voltage on your battery connector. Next plug your phone charger in. Now measure the voltage on your battery connector. That voltage will have to have increased. If not then the issue is either the port or the charging circuit.
Since iFixit does not yet have a guide for this, use something like this video to replace the charging port etc.
While you work on your phone, take lots of pictures. Once you are done with it, take those pictures and create a guide for iFixit. That will help the next person that has a device with the same issues as you do. It's easy and fun to create these guides. https://ifixit.com/Guide/new The iFixit community will appreciate this.
Repair is War on Entropy!
Был ли этот ответ полезен?
Счет 0
Добавьте свой ответ
Gervas Gideon буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 3
За последние 30 дней: 18
За всё время: 131
