The Theragun Mini is a handheld percussive massage therapy device that is designed to help soothe sore muscles, reduce tension, and improve overall muscle function.
Thereagun Mini (2022) Dead Battery?
My wife has a Theragun Mini from 2022 that no longer turns on and/or holds a charge. So of course, I came to iFixit for the teardown and I was sad to see there wasn't one.
Does anyone have a repair or tear-down guide for the 2022 what I guess is the original Theragun mini?
I found this video here which showed the result of cracking open the case. However, it doesn't show him putting it back together. HA!) You can hear him describe his theory as to the battery type possibly being three Panasonic 3400mAh batteries run in series (based on the tennis ball yellow/green color). He later reads a part number "31NR19/66" which unfortunately come in a range of sizes. And finally, he mentions that "they look like 18650s to me" which seem like a technical form factor.
While I'm not surprised that a 4 year old electronics product has died, I am very disappointed in Therabody for designing a product so aggressively anti-serviceable by an owner or third party.
Any advice or help would be greatly appreciated. Thanks.
Это хороший вопрос?
Счет 1
Добавить комментарий
1 ответ
Check out this threat from Oldturkey: How do I open the Theragun mini?
Был ли этот ответ полезен?
Счет 0
3 Комментариев:
Thank you, I did see it, but there wasn't really much of a resolution.
из
OK, I just thought it might be a good starting point! I haven't taken apart this theragun but have repaired their classic model. My advice is to go slow and use a heat gun or even just a really hot gel pack to try and loosen the adhesive. Be careful not to overheat the area of the tool wheere the battery is. Don't stress too much about bending/cracking the plastic since the rubber casing will cover most of it. Any cracks that do appear can be fixed easily with some Jet Glue/Super Glue and covered with Rubber Cemenet or Sugru
из
@daddysnorlax it's glued together like crazy :-) check this video before it disappears as well. Theragun does not like us fixing things :-)
из
Добавьте свой ответ
Daddy Snorlax буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 7
За последние 7 дней: 44
За последние 30 дней: 125
За всё время: 849
