Беспроводная швабра для влажной или сухой уборки полов; корейский продукт.
Autovis Replacement Charger Help, Please
My parents have misplaced the charger for this and I can't find where just the charger is sold. It is an AC 110-240V, 50/60Hz, but I don't know the mm of the plug in port to the device. Anybody know?
Это хороший вопрос?
Счет 0
2 Комментариев
Hi @jungune
Is there a product information label on the device somewhere? Near the charge port perhaps.
If there is, usually it specifies the voltage input requirements for the device i.e. DC voltage and polarity, (assuming it's not connected to AC voltage directly but through an AC/DC adapter).
Once that it known it makes it easier to find the correct adapter for it.
Post an image of the product label (if there is one) in your question. Here's how Добавление изображений к существующему вопросу
из
Thank you! Yea, I was having issues uploading all the images. User error. I've uploaded it now. I can see the voltage, but I don't know the mm size of the plug in to the machine. Is it standard? Aren't they different diameters?
из
Добавить комментарий
1 ответ
Выбранное решение
You can get universal power adaptors online that come with all the common sizes of barrel jack. As @jayeff mentioned, make sure that it supplies the same voltage as is listed next to the power port.
Был ли этот ответ полезен?
Счет 1
1 Комментарий:
I feel really challenged with this. How do I accurately measure the barrel jack? I guess if there are standard sizes, I go with the one that's closest to it? For some reason, I'm thinking if I'm a millimeter off, it won't fit, but I haven't even looked to see what sizes exist. 😅
из
Добавьте свой ответ
Jungun E буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 1
За последние 7 дней: 6
За последние 30 дней: 23
За всё время: 162
