Модель A1419 / EMC 3070 / середина 2017 г. / четырехъядерный процессор Core i5 с тактовой частотой 3,4, 3,5 или 3,8 ГГц, либо Core i7 с частотой 4,2 ГГц архитектуры Kaby Lake (идентификатор iMac18,3) / дисплей Retina 5K. Обращайтесь к более старым руководствам для iMac Intel 27" с дисплеем Retina 5K (конец 2014 и 2015 гг.), так как конструкция системы очень похожа.
2TB fusion hard drive dead...Replace with internal or ...?
So my iMac hard drive is dead, will not boot up. Should I open the computer or is there a way to simply use an EXTERNAL SSD? If So, how do I boot up from it if my internal hard drive is dead? Which external SSD should I use? or should I just swap out the internal dead one with an SSD. I also hear the the existing Fusion hard drive might have some other thing inside that I have to replace.
Это хороший вопрос?
Счет 1
Добавить комментарий
1 ответ
Any external drive HDD or SSD that is setup as a bootable drive will allow you to at least test the system drive. Here is a bit weird as the HDD drive is the 2TB that is actually holding you files, the small Blade SSD hidden on the back side of the logic board is a Cache drive to the HHD hence where the Fusion Drive comes from.
So you'll need to create a bootable drive to start things off. Frankly I would just grab a 32GB thumb drive to use here. Do you have access to a second Mac as that makes things easier. From it reformat the thumb drive with a GUID Journaled file system so you have a clean drive. Then download to it from the Apple Store the same version your iMac is using. Copy the file to to the drive and then convert it into a bootable image following this guide Create a bootable installer for macOS
Then with it plugged in it should boot-up! Now go to the menu bar to open disk Utilities and run Disk first aid on the top level point did it run through cleanly?
Был ли этот ответ полезен?
Счет 0
Добавьте свой ответ
Terry Carrigan буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 1
За последние 7 дней: 1
За последние 30 дней: 6
За всё время: 72
