Oppo A17 (номер модели CPH2477), выпущенный в 2022 году, оснащен 6,56-дюймовым HD+-дисплеем, 50-мегапиксельной основной ИИ-камерой, 4 ГБ оперативной памяти, 64 ГБ встроенной памяти и аккумулятором емкостью 5000 мАч.
Screenshot not working anywhere
Это хороший вопрос?
Счет 0
Добавить комментарий
1 ответ
It looks like you're browsing through iFixit for some troubleshooting! Here are some helpful ways to respond to Jack Ponder (Whirlpool washer) and Pankaj (Oppo A17).
Response for Jack Ponder: Whirlpool Washer Won't Advance
Jack mentions his older analog washer requires a "bump" to continue the cycle. This usually indicates a mechanical failure in the timer assembly.
  • The Timer Motor: In older analog Whirlpool machines, the timer uses a small motor and internal gears to advance. If a gear tooth is chipped or the motor is weak, a physical jar can help it "catch" and continue.
  • Worn Contacts: Internal electrical contacts can become pitted or carbon-scored, creating a dead spot that the timer can't bridge on its own.
  • Suggested Clarification: Ask Jack if the stall always happens at the same point in the dial, as this confirms a specific internal failure in the timer.
Response for Pankaj: Oppo A17 Screenshot Issues
Pankaj is unable to take screenshots on an Oppo A17 (model CPH2477). This is often a software setting or a hardware button issue.
1. Hardware Check
  • Button Combination: Verify they are pressing the Power and Volume Down buttons simultaneously.
  • Case Obstruction: Ensure a phone case isn't preventing the buttons from being fully depressed.
2. Software Gestures
  • 3-Finger Swipe: Oppo phones usually have a "3-finger swipe down" gesture. Ask them to check Settings > System Settings > Gestures & Motions to ensure this is enabled.
  • Storage Space: If the 64GB storage is completely full, the phone may refuse to save new images.
3. Restrictions
  • Privacy Settings: Some apps (like banking or "Incognito" tabs) prevent screenshots for security. Ask if it fails on the home screen as well.
Would you like me to help you draft the exact text to post for either of these users?
Был ли этот ответ полезен?
Счет 0
1 Комментарий:
@khushiupadhyay you need to at least delete this "Would you like me to help you draft the exact text to post for either of these users?" when you are using AI. Let me quote my colleague @dadibrokeit
Readers are cautioned to take this advice with a large grain of salt. All indications are that it is AI-generated and as such has no common sense. You should also not assume the person posting this has any knowledge of the subject at all, given that they are not the author of this post; an AI database produced it, so it is useless to ask for further information or clarification.
A word of caution. We do not mind if you use AI but you will have to be transparent about using it. You need to inform the community that your answers are generated/augmented by AI.
из
Добавьте свой ответ
Pankaj буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 1
За последние 30 дней: 10
За всё время: 119
