Информация по ремонту и поддержка ноутбука Acer Aspire E15, выпущенного компанией Acer в 2015 году. Номер модели: E5-575-33BM.
monitor is not displaying anything
I have this laptop it's monitor is not displaying anything, the power supply is still working fine and the monitor cables are connected however their seem to be a problem and the monitor is not showing any displays. Please help me out
Это хороший вопрос?
Счет 0
Добавить комментарий
1 ответ
Наиболее полезный ответ
I guess there are possible things to consider as a problem, depending on the brand of your laptop. Follow this step: 1. Display settings misconfigured; maybe it was set up to output to an external monitor only. Try Fn +a key like F4/F5/F8, depending on your laptop brand. 2. Faulty screen Backlight might have failed. Shine a flashlight close to the screen at an angle if you can faintly see any content, if you see it then the backlight or its inverter is the main issue. 3. BIOS/UEFI may be outdated or corrupted taht could prevent the display from initializing the BIOS.
Был ли этот ответ полезен?
Счет 1
1 Комментарий:
Try connecting an external monitor. If you can get a picture on that, then your display has failed. If not, it's an internal issue, possibly GPU or other hardware.
Come back and let us know what you find and we'll see if we can figure out what your next step should be.
из
Добавьте свой ответ
Ruben Serero буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 1
За последние 7 дней: 2
За последние 30 дней: 13
За всё время: 100
