MSI Thin 15 B12V, выпущенный в январе 2024 года, — это легкий игровой ноутбук с 15,6-дюймовым дисплеем Full HD с частотой обновления 144 Гц, оснащенный процессором Intel® Core™ i7-12650H до 12-го поколения и графическим процессором для ноутбуков NVIDIA® GeForce RTX™ 4050.
How to fix a cracked screen
I cracked the screen on my laptop and it still works but a small part of it is black
Это хороший вопрос?
Счет 1
Добавить комментарий
2 Ответов
If you want to fix this issue, you will need to replace the LCD panel. Here is a replacement part: https://www.newegg.com/lcdbros-msi-thin-...
Ifixit doesn't have a guide for this, but screen replacements are pretty similar across different models/brands of laptops.
You will need to remove the LCD from the screen panel. To do so, gently heat the edges of the screen. Next, run a thin wedge, fingernail, or craft knife along the edge of the screen to pop the clips. You will now have exposed the LCD panel. Remove any screws and clip connectors, and then swap out the old screen. Repete the steps in reverse order. You may need to add a few drops of glue to hold the glass cover in place if the origional clips broke during disassembly.
Let me know if you have any questions!!
Был ли этот ответ полезен?
Счет 0
If your MSI Thin 15 screen is cracked and showing a black area, the LCD panel is physically damaged and must be replaced. Cracks cannot be repaired — only replaced. First, confirm the exact model (check the sticker underneath). Order a compatible 15.6" panel matching resolution (usually 1920x1080) and refresh rate. Buy from trusted sellers like LaptopScreen.com, eBay (high ratings), or MSI parts distributors. Before replacing, power off, unplug, and disconnect the battery. Carefully remove the bezel, unscrew the panel, and swap the display cable. If unsure, take it to a repair shop to avoid damaging the hinges or connector.
Счет 0
Добавьте свой ответ
Mason буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 15
За последние 30 дней: 66
За все время: 415
