Nokia C32 — это бюджетный смартфон, представленный в мае 2023 года. Он входит в серию C от HMD Global и отличается лаконичным дизайном, стеклянной задней панелью и емким аккумулятором на 5050 мАч. Устройство оснащено двойной камерой с основным датчиком 50 Мп, сканером отпечатков пальцев в боковой кнопке и работает под управлением Android 13 (Go Edition) «из коробки».
Can I replace the battery
can i replace battery
Это хороший вопрос?
Счет 0
Добавить комментарий
1 ответ
Hi, @paulmbaundegwa I gotchu.
I could not find a guide to replace the battery, but this is what FixBot said:
The Nokia C32 uses a 5000 mAh Li-Po battery with the model number WT510 [source|new_window=true]. While the official user guide lists the battery as non-removable, the device is designed for relatively easy disassembly [source|new_window=true].
Required Tools & Parts
  • Replacement Battery: Model WT510 (5000 mAh).
  • Opening Tools: A guitar pick or plastic opening tool.
  • Screwdriver: A Torx T5 screwdriver is typically required for Nokia internal screws.
  • Adhesive Remover: 70% (or higher) Isopropyl Alcohol to loosen the battery glue.
  • Safety: Plastic prying tools (to avoid puncturing the battery).
Replacement Steps (General Procedure)
Based on disassembly reports [source|new_window=true], the process is as follows:
  1. Remove the SIM Tray: Use a SIM eject tool to remove the tray before opening the case.
  2. Open the Back Cover: Use a thin plastic opening tool (like a guitar pick) to gently pry the back cover away from the frame. Start near the SIM tray slot where the plastic is most flexible.
  3. Remove Internal Shielding: Unscrew the Torx screws securing the internal plastic cover/motherboard shield to access the battery connector.
  4. Disconnect the Battery: CRITICAL SAFETY STEP. Always disconnect the battery ribbon cable from the motherboard before proceeding to prevent short circuits.
  5. Loosen the Adhesive: The battery is glued to the frame. Apply a few drops of Isopropyl Alcohol around the edges of the battery and let it sit for 1–2 minutes to soften the glue.
  6. Pry Out the Battery: Use a flat plastic tool to slowly lift the battery. Do not use metal tools, as puncturing the battery can cause a fire.
  7. Install the New Battery: Place the new WT510 battery into the compartment, reconnect the cable, and reassemble the device in reverse order.
Safety Warning
Lithium-ion batteries can be dangerous if damaged. If your battery is swollen, do not apply heat. Ensure your battery is discharged below 25% before starting the repair to minimize the risk of a thermal event if accidentally punctured.
Был ли этот ответ полезен?
Счет 0
Добавьте свой ответ
Paul mbau Ndegwa буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 1
За последние 7 дней: 12
За последние 30 дней: 47
All Time: 364
