Информация по ремонту серии ноутбуков Dell Latitude 6000.
Charging port failure when charging
Why is my laptop switch off the power adapter once I connect to the charging port?
I have even tried other adapter and the same still happen
Это хороший вопрос?
Счет 0
Добавить комментарий
1 ответ
If your laptop switches off the power adapter as soon as you connect it to the charging port, the issue is often related to the charging port, battery, or motherboard power circuit. First, inspect the charging port for dust, bent pins, or debris and clean it gently with compressed air. A damaged DC jack can also cause a short, forcing the adapter to shut off for safety. Next, try removing the battery (if removable) and power the laptop directly with the adapter to see if the battery is faulty. You should also check the adapter cable for damage. If the problem persists, the motherboard charging circuit may require professional repair.
Был ли этот ответ полезен?
Счет 0
Добавьте свой ответ
stephen mutuku буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 7
За последние 30 дней: 16
За всё время: 136
