Умная колонка высотой 8,4 см (3,3 дюйма) с поддержкой Siri, разработанная Apple Inc. Выпущена 16 ноября 2020 года в цветах «серый космос» и белом. Позже была обновлена новыми цветами, такими как синий, оранжевый и желтый. Номер модели A2374.
HomePod Touch Sensor Issue Workaround No Replacement Needed
I have multiple HomePods with faulty touch sensors that would randomly trigger playback, which seems to be a fairly common issue based on other reports.
After looking into replacement options, I found that replacement touch panels are difficult to source. Since I rarely use the touch controls and mostly rely on "Hey Siri", I decided to try disconnecting the touch interface instead.
Using a teardown as a reference, I found that disassembly is relatively straightforward and the touch panel connector is accessible without too much difficulty.
I did not document the full process, but if you follow a teardown, the general steps are:
  • The base is held on with strong adhesive, so you will need to carefully pry it off
  • Remove a couple of T6 screws and one T8 screw
  • There are a few additional T6 screws securing the internal assembly
  • Once inside, locate the ribbon cable for the touch panel, which uses a small lever latch connector
  • Disconnect that cable, then reassemble everything
Note:
If replacement touch panels become available, you can replace the touch sensor at this stage instead of disconnecting it, since the connector is already accessible during disassembly.
Result:
You can disconnect the touch panel, reassemble the HomePod, and it will continue to function normally. The only thing that no longer works is the touch input.
I wanted to share this because I had not seen many people suggest simply disconnecting the touch sensor as a workaround. If your HomePod is experiencing ghost touches or random playback, this can be an effective way to keep it usable without replacing parts.
Since most smart speakers are primarily used via voice, losing touch functionality is not a major downside, at least in my case.
Be careful when removing the base adhesive and disconnecting ribbon cables to avoid damage.
Hope this helps others!
Это хороший вопрос?
Счет 4
Добавить комментарий
3 Ответов
Выбранное решение
Marking as answered since it wasn't really a question and more of a solution.
Был ли этот ответ полезен?
Счет 2
1 Комментарий:
I’d been having the same problem with one of our HomePod minis for several weeks. As we never use the touch interface and control the minis exclusively by voice, this was the perfect solution to the fault.
из
Hello @notlimahrelyt , thanks for the suggestion, but just to be clear, this is about HomePod 2? If that is true, the only guide I have found is in here, and I can not see the cable you mention:
https://es.ifixit.com/News/71957/the-hom...
THanks in advance!
Счет 0
1 Комментарий:
I have dissasambled my HomePod 2 and contrary to the Mini and old Homepod it will not boot uo without the touch panel connected.
You can disconnect it when the Homepod is running and it isn't bother by it missing then but thats problematic in my other ways.
из
My HomePod mini was stuck in a loop resetting. Followed the teardown instructions and reseated the touch panel, but that failed. I then disconnected it again, powered it on without it connected and THEN connected it. That did - good as new!
Счет 0
Добавьте свой ответ
Tyler Hamilton буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 30
За последние 7 дней: 235
За последние 30 дней: 1,240
За всё время: 6,533
