Инструкции по ремонту и разборке 14-дюймового MacBook Pro, выпущенного в октябре 2021 года, с процессорами M1 Pro и M1 Max от Apple. Модель A2442.
Can I replace or fix the microphone?
The microphone on my M1 Macbook Pro is very muffled.
After some investigation, I'm fairly sure the problem is a blocked grille. But it's hard to identify which (if any) of the hundreds of dimples on the left-hand side are actual holes and therefore need cleaning. Is there any information on this?
Это хороший вопрос?
Счет 1
1 Комментарий
Faced with exactly the same problem. I suffered for a long time. In the end, I solved the problem using an old toothbrush and isopropyl alcohol. I soaked the brush in alcohol and massaged the mesh for a few minutes. The computer was turned off. I waited 10 minutes and turned it on. The problem has been resolved
из
Добавить комментарий
1 ответ
Выбранное решение
I poked around with a pin in the 'holes' on the left hands side, and found some holes that were deeper than the normal divots, about 5 rows in from the right hand side, near the tab and caps lock key. Poking the pin into these fixed the problem.
Был ли этот ответ полезен?
Счет 1
Добавьте свой ответ
Ben буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 4
За последние 7 дней: 8
За последние 30 дней: 31
За всё время: 241
