Выпущенный в 2004 году, он неофициально известен как E60 M5.
The warning light comes on again
Am schimbat becurile de pe partea dreaptă spate la un bmw e60 din 2007 dar martorul cand pornesc masina revine.
Romanian->English translation
I changed the bulbs on the right rear side of a 2007 BMW E60, but the warning light comes on again when I start the car.
Это хороший вопрос?
Счет 0
Добавить комментарий
2 Ответов
Наиболее полезный ответ
@danluca, I had a Volvo that did the same thing; it turns out it was sensitive to differences in current flow between the old and new bulbs, so the fix was to also put new bulbs in the other side as well.
English->Romanian translation:
Am avut un Volvo care a făcut același lucru; se pare că este sensibil la diferențele de curent dintre becurile vechi și cele noi, așa că soluția a fost să pun becuri noi și în cealaltă parte.
Был ли этот ответ полезен?
Счет 2
My dashboard is displaying warning indicators; however, the vehicle systems remain fully operational. This issue originated following the installation of LED headlights.
Счет 0
1 Комментарий:
I assume you're referring to some sort of lamp warning indicator? You didn't tell us what kind of warning light you're seeing, and it's not always safe to make assumptions.
That being said, if you are seeing a bulb warning, it may not be surprising. If you originally had incandescent bulbs, probably halogen, and switched them for LED, then the car is going to see a huge difference in the power consumption since LEDs take maybe 1/10th the current that a halogen bulb would.
I'm not sure there's anything you can do about this; you might be able to add resistors to the load to increase the amount of current being drawn, but then you're defeating most of the advantage of having LED bulbs.
I'd suggest trying some BMW forums to see if someone else has managed to solve that particular problem.
из
Добавьте свой ответ
DAN LUCA буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 6
За последние 30 дней: 25
За всё время: 179
