Xiaomi Redmi 9 — это бюджетный смартфон от Xiaomi, выпущенный в июне 2020 года. Устройство оснащено 6,53-дюймовым IPS LCD дисплеем, основной камерой на 13 Мп, сканером отпечатков пальцев на задней панели, аккумулятором емкостью 5020 мА·ч и работает на базе процессора Mediatek Helio G80.
Speaker is not working
Sound only headphone, speaker not working. How to fix it?
Это хороший вопрос?
Счет 0
Добавить комментарий
1 ответ
@monoarakha45910 could be the speaker but it could also be the headphone jack. After all, the headphone jack functions also acts as a switch to turn the speaker either off or on, depending on if you insert or remove the headphones.
The headphone jack is on the charging board. To replace the speaker, and since ifixit does not yet have a guide for this, use the one from here. For the headphone jack (charging board) use this guide. Both of these are written is Spanish. Use a browser that does the translating for you, if needed. Replacement parts are readily available at many online places.
While you work on your phone, take lots of pictures. Once you are done with it, take those pictures and create a guide for iFixit. That will help the next person that has the same issues with their device. It's easy and fun to create these guides. https://ifixit.com/Guide/new The iFixit community will appreciate this.
Repair is War on Entropy!
Был ли этот ответ полезен?
Счет 0
Добавьте свой ответ
Monoara Khatun (Modina) буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 0
За последние 30 дней: 12
За всё время: 102
