Тонкая версия классической Xbox 360 с жестким диском на 250 ГБ и встроенным Wi-Fi. Для ремонта требуются аккуратное поддевание и специальные инструменты.
Random freezing, restarting by itself
My xbox is freezing during gameplay, mainly at the first loading screen I come across, rarely at the dashboard and I have to unplug the power cord to shut it off. Sometimes the wifi card isn't detected as well. I can play Rainbow Six Vegas 2 for 10 minutes before it abruptly shuts on and off by itself.
I've tried cleaning and repasting it, didn't work and I can confirm temps are low. I've also reinstalled the latest update.
Это хороший вопрос?
Счет 0
Добавить комментарий
1 ответ
Наиболее полезный ответ
Hi!
Did you also tried to replace the HDD?
I would do that first and install the software again.
Guide: Замена жесткого диска Xbox 360 S
If it's still failing, try to replace the Wifi card and see if that solves anything.
Guide: Замена платы Wi-Fi Xbox 360 S
I would try a new HDD first, you have some cheap ones at AliExpress and they do work fine.
Can you let us know how that goes?
Thanks!
Xbox 360 S Жесткий диск Изображение
Инструкция
Сложность:
Очень просто
1 - 5 minutes
Xbox 360 S Плата Wi-Fi Изображение
Инструкция
Сложность:
Умеренно
5 minutes
Был ли этот ответ полезен?
Счет 1
4 Комментариев:
I've tried removing the HDD before and it didn't do anything, I can run it without the wifi card and I still get the same issues so isn't that.
из
If all the above didn’t worked, same for the HDD, then you most likely have motherboard issues. Most likely the internal memory on it.. I recommend to replace that. It won’t be easy as soldering is required. You can replace the motherboard but this will be expensive.
из
@dan0 I have the Trinity model so was able to remove the 4gb internal memory, which fixed freezing during loading screens. The games now just freeze later on. The dashboard also wont respond to my input at times, but I'm able to open the smaller menu with the xbox button which does work.
из
Okay! That’s a good thing!!
Please replace it for a new one and install it completely as new.
Does thet work?
Thanks!
из
Добавьте свой ответ
MangosteenJuice буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 2
За последние 30 дней: 16
За всё время: 160
