Руководства по устройству и устранению неполадок для Lenovo ThinkPad L490. Lenovo ThinkPad L490 — это американский ноутбук, выпущенный в 2019 году. Используется в качестве бизнес-ноутбука.
Not powering up at all
looking for solution
Это хороший вопрос?
Счет 1
1 Комментарий:
@teogboin does it give you any sign of life? What have you checked and what have you tried?
из
Добавить комментарий
1 ответ
@teogboin Start off with the easy things. Disconnect the power from the computer by unplugging the power cord from your computer. Disconnect all external devices from the computer. Disconnect the battery Now hold the power button depressed for about 30sec-1min. Reapply the AC power adapter and see if your computer does show any sign of life.
Now, here are some generic steps you have to take for the initial troubleshooting. First you need to check your power supply. Make sure it has the proper voltages. Check to make sure that the connectors are not bend etc. Check the DC-in jack of your laptop. Make sure there is no corrosion, debris etc. that prevents it from working. Clean it of any debris etc, use a few puffs of air to clean it out. If none of this works, get a ammeter and see if your laptop draws any amperage from the charger. After that, you need to check and see if your motherboard even gets power. For that of course, you need to open it up. Post Some good pictures of what you see. That way we can see what you see. Добавление изображений к существующему вопросу
Let us know what you find out. Use the Lenovo ThinkPad L490 And L590 Hardware Maintenance Manual to work on your Lenovo
Был ли этот ответ полезен?
Счет 0
Добавьте свой ответ
T.E O'gboin буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 11
За последние 30 дней: 20
За все время: 141
