Which sensor rail do I need
I need a new LEFT sensor rail for my switch mod# HAC-001(-01) starting letters of my serial# XKW I can use the standard or do I need OLED?
Это хороший вопрос?
Это хороший вопрос?
Hi Stacy,
Correct. You can use all the standard models their rails.
Do not use the OLED one. This one is different.
Here is the guide if you need it: Замена направляющей левого Joy-Con для Nintendo Switch
Please let us know how the repair goes!
Был ли этот ответ полезен?
За последние 24 часов: 0
За последние 7 дней: 2
За последние 30 дней: 13
За всё время: 113
2 Комментариев
I’ve answered my own question I’m pretty sure it’s standard since it’s 5 screws.
из Stacy Mae
Yeah, I'm fairly certain that the Joy-Con rail designs are the same between models. Just don't try to replace an OLED rail with an original one, or vice-versa. So long as it's a 2017 or 2019 model Switch, you should be able to use a rail from either.
из Fixer of Stuff
