Выпущен в октябре 2021 г. Вес 204 г, толщина 8,8 мм Android 11, обновление до Android 13, MIUI 14 Накопитель 128 ГБ / 256 ГБ, без слота для карты памяти
Power button not working it went inside
Power button not working and went inside
Это хороший вопрос?
Счет 1
3 Комментариев:
What happened to the power button? Went inside where? More info would be useful when trying to get help.
из Поделиться
@somerandomguy_1 If I had to guess, I'd say they mean that the power button is stuck, but yeah, more information would help.
из Поделиться
@fixerofstuff Good point. @naraharise87483, does the button feel like it's jammed by dirt, or did it sink in after a drop? If the button still "clicks", you might want to use Isopropyl alcohol on a Q-tip to clean it; otherwise, the motherboard might have shifted inside the case, causing the button to get stuck underneath the screen.
из Поделиться
Добавить комментарий
2 Ответов
Hi, @naraharise87483 I gotchu.
I would say to use some tweezers from a Precision Tweezers Set and try tweezing the power button out.
Also try opening the phone and locating the power button.
Three slim tweezers for holding and manipulating small and delicate components. Blunt, pointed, and angled versions. Ergonomically shaped and ESD-safe. Includes a sturdy storage pouch. For electronics and other tasks where keeping a good grip is important. Изображение
Товар
$11.95
Был ли этот ответ полезен?
Счет 0
The phone's fingerprint sensor is not working.
Счет 0
Добавьте свой ответ
Naraharisetty Ramchandra буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 1
За последние 7 дней: 14
За последние 30 дней: 86
За все время: 507
