Настольный компьютер eMachines 2220.
Why does mine keep giving a boot error
Its something with the disk drive but it says something about master and slave slots
Update (06/16/26)
Turns out it was a dead cmos battery
Это хороший вопрос?
Счет 1
5 Комментариев
What is the actual error message? Does the computer keep restarting after the error message?
из
It also doesn't read the disk drive
из
Are you able to enter the bios by pressing DEL button upon startup and look at your boot priority? You can disble the disk drive which could interfere with your boot sequence
из
I was able to and doesn't read the hdd it reads disk sorry for inconvenience
из
Try holding down the shift key when turning on your computer and see if it takes you to the advanced boot manager.
из
Добавить комментарий
2 Ответов
Выбранное решение
@caseyteska36918 your computer does not "see" the boot disk. Either you have a bad HDD/SSD or corrupted OS boot files. Enter your computer's BIOS on startup and check the boot sequence to make sure it is not configured to boot from a Network. Make sure your hard disk is listed in the boot sequence. Make your hard disk the first device in your boot order. If is is bing seen etc. then you could try to repair the OS or reinstall it. Also reset your BIOS to factory default settings.
If your Boot drive is not visible it will have failed. In that case you would need to replace it and reinstall an OS.
Был ли этот ответ полезен?
Счет 2
3 Комментариев:
Prob a bad hdd because the computer tower has the original hdd and it's from 2008 so could be
из
@caseyteska36918 yeah, that would be my first guess be as well.
из
Yea it's probably a bad hard-drive but it's not clicking like how bad ones do so might be corrupted
из
Счет 1
1 Комментарий:
@caseyteska36918 definitely unexpected :-) but glad you got it figured out and fixed!
из
Добавьте свой ответ
Casey Teska буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 3
За последние 7 дней: 9
За последние 30 дней: 18
За все время: 151
