Руководства по ремонту и информация о разборке для 11-дюймового iPad Pro 4-го поколения от Apple. Выпущен 18 октября 2022 года.
Battery Replacement and Adhesive Strips
After four long years of use the battery on my iPad Pro is lasting less and less time. I am thinking about replacing the battery. Looking at the repair manual for the third generation which uses the same battery I have two questions. Can I use the same manual? or should I use the screen replacement manual for the appropriate parts on the actual manual, that is, generation 4 and substitute the third for what is appropriate? My main question is replacing the Adhesive strips for mine. It is not even mentioned in the third manual and they are $170 for my model. Why are these so expensive. Are they needed for battery replacement? I want to do an excellent job, but that price is way out of line compared to other models. What's up? Thanks for the help.
Это хороший вопрос?
Счет 2
3 Комментариев
Let me see what the IFIXIT team can tell us. That won't be until Monday at the earliest. Hang tight!
из
@danj, thank you for passing this along!
из
Добавить комментарий
2 Ответов
Выбранное решение
@rogercole
Sorry for the delay in getting back to you!
The display adhesive is necessary for this repair. To access the battery on any iPad, you have to remove the display - there's no way around it. Once you remove the display, you'll need new adhesive to reseal it properly.
These are custom-cut adhesives designed to fit your specific iPad model exactly to spec. They'll bond the glass to the frame properly and ensure a secure seal.
I'd recommend following the guide specific to your model (4th gen) rather than the 3rd gen guide. Even though they use the same battery, there are internal differences between generations that could affect the repair process.
I'm also looking into the cost of the 4th gen adhesive for you. I'll follow up when I have an update.
Был ли этот ответ полезен?
Счет 2
6 Комментариев:
Thank you Kris! I knew I wanted to replace the strips, but that price just made me back up and say whoa. There not being a repair guide for the 4th gen I suppose I will have to wing it on a few steps. Thanks again for looking into this for me.
из
@rogercole, you're welcome!
We looked into the pricing with our ecommerce team, and there's definitely an error in the price listing - that's not the correct price.
We're working to get it fixed now. I'll reach out as soon as it's corrected.
Thank you so much for your patience and for bringing this to our attention.
из
@krisrodriguez - Thanks Kris!
из
@krisrodriguez Thanks very much. I will more than likely be sending you an order before long. Wish me luck on the repair. My hands are not as steady nor my eyes as focused as they once were. I appreciate everyone for the prompt response and for your service.
из
@rogercole Fixed! The price is now where it should be ($4.99) and we wish you much luck on the repair!
Many of us have similar limitations, but the key is to just go at your own pace and take breaks when you feel yourself getting a little tired. At least that's what I do for my own repairs. Some are simple and done quickly and others, especially with iPads require a little more patience on our end. Thank you again for understanding and please reach out if anything else comes up.
из
Показать ещё 1 комментарий
Personally? If I were you I’d step away from the iPad and find a reputable repair shop. My reason for this is a replacement screen for a iPad Air isn’t cheap for any model. It comes as a screen and touchscreen all in one unit. If you have no experience removing these screens, chances are you’ll break it. Just being honest. If you take it to a decent shop they’ll be able to fit the new battery (usually comes with adhesive installed) and if they break the screen they should replace the screen. All you’d have to pay is the price for the battery replacement. Ring a few shops for prices but make sure to ask if they break it they’ll replace it.
Used to work as a mobile repair technician and have repaired countless phones and iPads etc.
Good luck whatever you decide to do.
Счет 0
1 Комментарий:
Thank you! Yes, I have thought of this as well. I enjoy tinkering with electronics. I have the tools might as well use them. If I break it then it would give me a strong reason to buy a new one.
из
Добавьте свой ответ
Roger Cole буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 1
За последние 7 дней: 19
За последние 30 дней: 98
За всё время: 495
