Browser keeps going back a page
Update: Well this is the weirdest thing ever. I have completely switched my computer from my Windows laptop to a Mac mini and the issue is still occurring. Again, I replaced my mouse awhile back to alleviate the issue, so I still don't think it is the mouse. I am not even touching my keyboard when this happens sometimes, so that probably rules out the keyboard. I am completely out of ideas here. I am going to switch back to my old mouse to see if that helps, but I doubt it will.
I am not sure if anyone can help with this, but thought I'd check here anyway. I have been trying to find a cause for this issue for months and have found no solutions whatsoever.
This has happened in both Chrome and Edge, so I know it must be a Windows issue. So, when I am in my browser, and I am doing work, being productive, without any clear cause, the browser page will revert back to the previous page. In some of the work I do, this results in lost work and having to start over which is highly annoying and results in a lot of wasted time and aggravation.
It does not have anything to do with my mouse or keyboard, as both of those have been replaced and it has not solved the issue. There are no keyboard hotkeys assigned to move the browser page forward or back. I don't use the touchpad but no gesture settings are assigned to perform this function. I am at my wit's end and am seriously considering switching my whole set up to my Mac mini, which would be a hassle but I am so tired of this happening with no fix or useable advice.
I have searched the internet many times for a solution, and this seems to have been an ongoing issue with Windows on different PCs for a long time from what I can see, so I am hesitant to say that it is only an issue with my specific computer.
Has this happened to anyone else, and did you ever find a solution? The most advised solution from any kind of support has been to do a clean Windows install which seems like a huge deal with no guarantee of a fix.
Это хороший вопрос?
Счет 0
4 Комментариев:
Hi @pinkskeleton914
Try using Firefox and see if that works for you.
Never had this problem using it
из
Nope, unfortunately that did not work either. Just lost 15 minutes worth of time and money due to the browser hopping back a page.
из
@pinkskeleton914
Just curious, is your mouse Bluetooth or USB?
I realize that you said that you replaced the mouse but did you replace it with one having the same connection type?
If it is a BT mouse try using a USB mouse and check.
Also if it was a BT mouse did the problem occur wherever you used the computer or only in one location?
Just trying to isolate further as you've changed computers and the problem is still there.
из
The mouse I was using is a USB mouse, I have switched back to my old bluetooth mouse. I have not seen the issue 'yet' but it happens so randomly, there is no telling when or if.
I was using this old BT mouse previously a few months back when the issue was occuring, but only with my Windows computer.
I am using my Mac now with the BT mouse. So we shall see...
I appreciate your help!
из
Добавить комментарий
