Switch lite screen misaligned
Hi, my switch lite screen is misaligned and looks wonky. How would I go about fixing it? Is it possible to do without opening?
Это хороший вопрос?
Это хороший вопрос?
Hi!
Thank you for the pictures!
As in the last photo it's indeed slightly misaligned.
Since when did this happen?
Anyway, the only way to fix this, is to open it up and check how the screen is sitting in there. If possible, try to align it manually (carefully).
Those screens are incredible fragile, so be careful all the times.
In the worst case, a screen replacement is needed, but I don't think this will be the case.
Guide for how to get there: Замена ЖК-экрана Nintendo Switch Lite
Please let us know how it goes!
Был ли этот ответ полезен?
It is new, I noticed it after I set it up, problem is it's the japanese version so Nintendo won't accept the warranty in UK. I will try to get used to it for now as I know it isn't the worst but if not I will try the repair myself. Thanks for the responses.
Ah, definitely a factory fault here. Whenever you go back to Japan, you can get it swapped for a new one. I agree, whenever it's completely new, I won't repair it as well. Have a great day!
За последние 24 часов: 6
За последние 7 дней: 28
За последние 30 дней: 80
За все время: 301
2 Комментариев
Hi!
Can you share some pictures with us, as how it looks like? This will help us to identify the issue.
Добавление изображений к существующему вопросу
Most likely it's just the screen and yes you most likely do need to open it up.
But we cannot say anything for sure without the photos.
Thank you!
из koppie007 Поделиться
Images added
из Awais Ali Поделиться
