Минивэн пятого поколения дебютировал на Североамериканском международном автосалоне 2007 года; внешний вид автомобиля разработал Ральф Жиль.
Air conditioner not.working
After replacing tipm my air conditioner is no longer working. Replace relay, its fully.charged but.still doesnt work
Это хороший вопрос?
Счет 0
4 Комментариев:
This question was migrated from https://meta.ifixit.com/Answers.
из
Hi @kathy21141
As you mentioned replacing the tipm, I assume that the air con is in a motor vehicle.
If this is correct, what is the make, model and year of the vehicle?
Moderator.
из
@jayeff 2019 dodge grand caravan
из
@kathy21141
Does the blower motor work when you turn on the air con?
Can you hear the compressor clutch operate when you turn on the air con - with the engine idling there should be a clunk sound as an electric clutch engages the compressor pulley so that the serpentine belt turns the compressor?
из
Добавить комментарий
1 ответ
If the A/C stopped working right after replacing the TIPM, the issue is likely related to power, programming, or communication rather than the refrigerant charge itself.
A few things to check:
  • Make sure the new TIPM is the correct part number and properly programmed for the vehicle
  • Check all A/C-related fuses again, even if they look good visually
  • Verify the compressor clutch is getting power when the A/C is turned on
  • Scan for trouble codes because some TIPM replacements can trigger communication or sensor issues
  • Check the pressure switch and A/C compressor connector for loose wiring during the repair
  • If the radiator fan is not coming on, the A/C may also stay disabled
Since you already replaced the relay and confirmed the system is charged, I would focus on electrical diagnosis next. A multimeter or scan tool will help much more than replacing more parts randomly.
Был ли этот ответ полезен?
Счет 0
Добавьте свой ответ
Kathy буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 8
За последние 30 дней: 21
За все время: 220
