ΠŸΠ΅Ρ€Π΅ΠΉΡ‚ΠΈ ΠΊ основному ΡΠΎΠ΄Π΅Ρ€ΠΆΠ°Π½ΠΈΡŽ
ΠŸΡ€ΠΈΡΠΎΠ΅Π΄ΠΈΠ½ΡΠΉΡΡ ΠΊ сообщСству Ρ€Π΅ΠΌΠΎΠ½Ρ‚Π½ΠΈΠΊΠΎΠ² - Π‘ΠΎΠ·Π΄Π°ΠΉ Π°ΠΊΠΊΠ°ΡƒΠ½Ρ‚
БСрия ΠΌΠ½ΠΎΠ³ΠΎΡ„ΡƒΠ½ΠΊΡ†ΠΈΠΎΠ½Π°Π»ΡŒΠ½Ρ‹Ρ… струйных ΠΏΡ€ΠΈΠ½Ρ‚Π΅Ρ€ΠΎΠ², сканСров ΠΈ ΠΊΠΎΠΏΠΈΡ€ΠΎΠ² ΠΎΡ‚ HP. НомСр ΠΌΠΎΠ΄Π΅Π»ΠΈ CX042A.
How do I fix the printer display buttons
The buttons on the touch screen panel do not press. There seems to be cork like substance, which has come off in some keys. Could this be the problem?
Π˜Π·ΠΎΠ±Ρ€Π°ΠΆΠ΅Π½ΠΈΠ΅
ΠžΡ‚Π²Π΅Ρ‚ Π½Π° этот вопрос Π£ мСня Ρ‚Π° ΠΆΠ΅ ΠΏΡ€ΠΎΠ±Π»Π΅ΠΌΠ°
Π­Ρ‚ΠΎ Ρ…ΠΎΡ€ΠΎΡˆΠΈΠΉ вопрос?
Π‘Ρ‡Π΅Ρ‚ 1
Π”ΠΎΠ±Π°Π²ΠΈΡ‚ΡŒ ΠΊΠΎΠΌΠΌΠ΅Π½Ρ‚Π°Ρ€ΠΈΠΉ
2 ΠžΡ‚Π²Π΅Ρ‚ΠΎΠ²
If none of the touchscreen buttons respond at all, it might be that the touch panel itself has crashed or broken. Unplug the printer from the power socket for a few minutes. If this doen't work it may be that the display panel itself is failing hardware-wise.
Π‘Ρ‹Π» Π»ΠΈ этот ΠΎΡ‚Π²Π΅Ρ‚ ΠΏΠΎΠ»Π΅Π·Π΅Π½?
Π‘Ρ‡Π΅Ρ‚ 0
You can replace the control panel by following the instructions to remove the print head, the panel has to be disconnected from the ribbon cable to remove the top part of the case.
Panels are available from places like eBay and AliExpress.
I have just scrapped an HP5520 as its no longer worthwhile to repair, its done 23,000 pages.
I have removed the control panel, which is in excellent condition and will be putting it up on eBay in the UK, the rest of the inside is coated in black ink and dust.
Π‘Ρ‡Π΅Ρ‚ 0
Π”ΠΎΠ±Π°Π²ΡŒΡ‚Π΅ свой ΠΎΡ‚Π²Π΅Ρ‚
Cedric DSouza Π±ΡƒΠ΄Ρƒ Π²Π΅Ρ‡Π½ΠΎ Π±Π»Π°Π³ΠΎΠ΄Π°Ρ€Π΅Π½.
Бтатистика просмотров:
Π—Π° послСдниС 24 часов: 1
Π—Π° послСдниС 7 Π΄Π½Π΅ΠΉ: 4
Π—Π° послСдниС 30 Π΄Π½Π΅ΠΉ: 15
Π—Π° всё врСмя: 93
